Technical really stubborn multi air bleed or failed multi air?
Well... if the head gasket is as I said, teared open between cylinders (1/2 - 2/3 - 3/4) the air you put in cylinder 1 will go out in cylinder 2 and chances are cylinder 2 intake valve it's open.
i think im going to take my multi air off to check but the only cylider that had air coming out of it was 4 because its intake valves were open either way im going to have to replace the head gasket hopefully its just that because a head gasket kit it a lot cheaper than valves
Interesting to see the operation in above videos.:)
My thoughts are a bit more basic, with regards to the initial leak down test, assuming as is said that the multair unit cannot hold valves down on it's own, then if valve timing is correct and engine set at TDC on the firing stroke for that cylinder and crank /cam locked up, then if air pressure via the leak down test is applied, then if air is leaking out it can only be through a faulty multiair unit/valves jammed open or head gasket between the adjoining cylinder.
Normally I would have inlet manifold off and be able to see if air was escaping past the inlet valves on the cylinder being tested directly into those inlet ports related to that cylinder, so if no air escaping into ports, but air escaping into adjoining cylinder then one must assume an issue with the head gasket into that next cylinder.
Apart from exhaust valves on that cylinder also, unless they have been eliminated obviously.:)
I try to break things down for simplicity, so in effect an engine is basically just a pump with pistons and valves, to trace where the loss is going.
Is it possible to do the leak down test with the multiair/brick unit off the vehicle or does it hold the cylinder head tight also?
If possible and exhaust valve cam lobes are closed on firing stroke on that cylinder that is locked up to do the leakdown test, so all inlet and exhaust valves are supposedly shut on that cylinder it should be possible to determine if any air loss is via head gasket or actual engine valves in cylinder head.
yea ill do more testing looking at the top of the intake valves with my eye-crometer and they look like theyre all properly seated, ill do a leak down test and pump some compressed air in. id assume my head bolts are fine but ill check those the only annoying thing is to get to them you have to pull the camshaft housing but ill prbably do that eventually after i dig into it more. im starting to lean towards blown headgasket inbetween cylinders because while one cylinder is going up and compressing another one is going down causing a vacuum and that might cause the 0 psi compression. idk if that makes sense
ok so i took the multi air out so none of the valves should have been open and i put air into cylinger 1, had plugs in 2 and 3 and took the pug out of 4. i could hear air coming out of the intake slightley but mostly coming out of cylinder 4, i think next step is to pull the cam and check it with nothing touching the valves
ok so i pulled out my camshaft housing or whatever its called so all the valves would be in the closed position and when air is applied to cylinder one and cylinder 2 and 3 were plugged i could hear it come out of the intake slightly but mostly cylinder 4 so i figure the next step is to pull the head check the head gasket and check the valves
Did you examine the multiair for some valve plungers stuck in the open position (like protruding outwards and hard to push back in)? Are they all higly mobile and fall easily into the closed position by their own weight when turning the multiair upside-down (or at least after giving them a tiny push)?
none stuck in the open position but if i have it sitting upside down if i push one down it doesnt return bacck , it feels like theres no spring and its just hydraulically driven
Just a little concerned when you mention plugging other cylinders when testing cylinder one etc, that maybe you are not following the correct guide for doing the leak test and maybe getting odd results.
Usually when I do a leak test I have all the spark plugs out , the valves closed on the cylinder I am testing , the piston in that cylinder at TDC, the crankshaft locked at that position so engine cannot try to turn and then I put the 90-150psi of air into that cylinder with a good air tight fitting, so then any air escaping from what ever source can be identifyined correctly.
Also relying on the camera to see if valves shut is not 100% as they can appear closed but still give a poor seal in my experience.
i wasnt doing a leakdown test i was joust pumping in compressed air cause in theory with no camshaft all the valves should be closed air should only be escaping through the rings i can see about doing a proper leakdown test today
But even with poor seal, they wouldn't give you 0 psi on compression test, would they?
With valve issue you can get 0 psi unlike a piston which even with broken rings will still have some slight sealing effect in my experience. Even more so if just doing a compression test.
Personally I would do a proper leak test as described with piston locked at TDC to get the most accurate result on each separate cylinder, so if air blowing out of eithjer the inlet or exhaust port you will immediately know a valve is the problem, but if nothing from those ports but air is blowing out of the cylinder next to it's spark plug hole that would point to the head gasket direction.
I don't mean to go on but I have used this test on many vehicles petrol and diesel since the 1970s and it is the most accurate way of pinpointing a problem like this providing it is done as described.
A compression test will tell of a low compression on a cylinder, but it will not tell you why.
I have one of the vacuum testers as @Zardo shows and they are useful providing you can get a good seal on a port etc.
I used to go to an engine machine shop and they had an electrical vacuum pump system that did a similar job on a cylinder head when you took it for skimming flat after a suspect headgasket etc. assuming ports are not linked internally, although they mainly used it to try and get you to let them do a full valve job at extra cost.;)
OK so I did a compression test other 3 cylinders plugged no cam so the valves should be in the closed position I mostly heard air leaking out of the intake but I didn't have my downpipe completely off so. I'm not. Sure if air was coming out the exhaust for sure, I'm starting to wonder if ita a small bend in the valves or just valves not seating
im confident that somethings up with the valves and they're either a little bent or just arent sitting properly but im nervous to pull the trigger on parts because theres no smoking gun
Are the manifolds off when you are doing this test so that you can see if the escaping air is going out of a suspect valve or are you just going by the percentages?
I am getting a little confused (not that that takes much with me.;)) But What I call a compression test is with the valves all working and connected , all the spark plugs out and the compression test gauge screwed into the spark plug hole of the cylinder being tested and the engine cranked over with a good battery roughly ten revolutions, some people also hold accelerator pedal down, but largely irrelavant on modern ECU controlled vehicles. I would expect on a good engine reading ideally around 180psi. on each cylinder.
What I call a "leak test" is as I have described earlier, again with all spark plugs out, but with the cylinder being tested at Top Dead Centre and the valves closed on that cylinder, with the engine /crankshaft locked in that position preventing the engine from moving, high pressure air is introduced via the spark plug adaptor (I use 150 psi) and all exits from the engine are checked for air escaping, valves/pistons etc. This test is then repeated with each other cylinder. In general terms I would expect a slight loss past the pistons and no where else, so nothing past valves into ports or gaskets into adjoining cylinders etc.
Incidentally I ensure no air leaks from the high pressure hoses and the air compressor, well away from the test so that it is easier to actually hear where air is escaping.
yea this last one with the pictures was a leakdown test the tested i got was a little weird cause it only wabnted about 30psi though i dint think my air compressor could keep up with 100+psi i had it hooked up to a specific cylinder and i didnt have it locked at tdc for each cylinder i jost had it locked at tdc for cylinder 1 and 4 with the timing tool so the crank wouldnt move, i dont have my intake/exhaust out yet because its so annoying lol but i can hear the air escaping out of the throttle body.
Hard to pin point exactly the problem then.:(
I mean, doesn’t air coming out of the intake point to the valves not seating? I think what happened is that when this all went down, my oil pump didn’t seize, but the resistance increased dramatically and that broke the keyway off my timing pulley. I thought it didn’t slip, but there was nothing preventing it from rotating besides the crank bolt. I figured I got away without any problems, but now I’m thinking the pistons might have given the valves a little kiss.
I’m not sure what I can do to prove it without pulling the head. Maybe I could put some oil down the intake port and see if it leaks into the cylinder?
It does sound like valve issues especially if your 100psi compressor was only showing 30psi presumably from the leakage..
If the keyway sheared then it certainly points to some sort of hard contact.
The suspicion was always there re valve and piston contact , but you had no obvious signs when using the camera and felt the valves were closing I recall.
Always easier with manifolds off to detect leak at ports, but air loss from throttle body certainly looks like it.
It will be good to get to the bottom of it.:)
Normally an hour spent with the leak off test is fairly conclusive, although it takes a little longer on diesels due to removing injectors or heater plugs to do the test.
Probably hard to get oil through inlet ports to show much.
Yea I'm definitely going to take the manifolds off it's just a bit involved I feel like my might have a tiny bend in them, also that leak down tester was weird it was like hook it up to an air compressor until the leak down gauge reads 0 then hook it up to a cylinder. I would have much rather just had 2 pressure gauges and a regulator so I could see more accurately.
You would be well served to look up how leakage testers work.
