there is no other bp number on the side.please see photo. this is all it says on the radio. Thanks
Sorry, without the serial number, I can't get the code for you.
This must be the first Blaupunkt radio ever, not to have one.
is this a panda or punto..??
should be SOME ID labels on the unit..??
Charlie - Oxford
It's a panda it has this on top. Does this help ??
AFAIK the dolby sticker is a licensing thing.., " Dolby Sound.."
it'll be BUILT by Blaupunkt / Grundig. etc.
I'm sure Davren will be able to get you a code now..
however- the power needs to stay on the clear the WAIT message![]()
Just found the BP number
BP338964202609
Hello!
My friend has a stock Punto CD Head Unit. He got the code when bought it, but it didn't accept it. Then he generated a code from the serial number, got the same code, but still the head unit does not accept the code. How is this possible? What to do to unlock in this case?
Hello. What type you have? Your radio seems missing the switched +12V line. That's usually a yellow cable. It depends on your type of radio to where to put it. you must look for the pinout of your radio, which should be on a sticker on top of it. The switched +12V looks pretty much this: _/_ + or similar.
If there is a cable on the noted pin, then you need a multimeter to check if there is +12V when ignition is on.
What is the serial number?
What code have you got?
Sorry, I received the details now.
The Head unit doesn't accept the code on the code card, only displays WAIT.. message after entering it.
What can my friend do with this radio? Is there any chance to make it work?
would it be possible to generate a code for this radio:
BP-7 643 383 316
735 371 187
815 BP338330600676
