Technical Radio swap
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
R32Egor
Upper Austria
HI all,
I would like to replace the Standard radio with an aftermarket
Would this effect the Bluetooth phone functions or is this separate from the radio?
I presume this would effect the BLUE and ME correct? or is this with the Bluetooth stuff?
Sorry didn't see you are in Austria but the links are still good info.
Depending on the year, you can get a adapter plate to fit a standard din radio, get one with all the toys and a steering wheel interface then you'll have control via the steering wheel built in streaming Bluetooth etc etc, get one with a external mic, (personally I would buy Alpine but it's up to you) the blue and me being redundant, you may well loose the dash display though not sure re this.
Something like this maybe, it has serious spec for not a lot, with a huge range of audio control IF you know what you're doing, read through its specs.
http://caraudiosecurity.com/cde-173bt-cd-mp3-usb-bluetooth-ready-tuner
Fascia adapter
http://caraudiosecurity.com/ct24ft16-fiat-500-2008-single-din-facia
This MAYBE the steering wheel adapter
http://caraudiosecurity.com/connects2-beat-patch-lead-ctbeatlead
