- Joined
- Jan 16, 2005
- Messages
- 10,608
- Points
- 1,450
PhatAshKi said:Ok most of it is in, been doing bits after work, Gonna finish it completly sunday, Now to help with the cooling and heat issues i've got 2 12v fans, 1 to suck the hot air out of the bottom encloser (which leads into the main build) where the small amp is and another is gonna be in the parcel shelf to suck hot air from the main build where the main amp and capacitor is. Now technically that should help draw the hot air away from the amps etc but they obviously need to be powered.
Im thinkin of having a relay with the main feed coming from the fused dist block and the switched live would be the 12v positive feed from my head unit. This would also be used for the remote for my amps if it works, Wat im asking is will this be ok to use to turn on the amps?? Or can i only use the hu feed?
As always im sure Chaos would know his stuff
Also as asked above would my 10cm be able to be heard ova me subs or would i need to upgrade to 6"'s in the doors at a later date?
Speakers first off - if you can fit the 6s/6.5s in, then fit them - should be more efficient due to the much larger cone area.
You can use a relay As you said use the disi power as the main feed but use the remote cable from the HU for the switching +12V.
I do have a link somewhere which goes through it all and has Maplins codes for the bits There's also a good page about relays on www.bcae1.com
Here's the link - http://www.talkaudio.co.uk/vbb/showthread.php?t=17895
HTH
