If I have Vista Home Premium 32bit, can I use the same licence for a 64bit version? if so where can I get a copy on the cheap?
It was pre-installed. Sticker is on the front door of the case.OEM or retail key?
Agreed with Chris, although there is a workaround here:
http://forums.steampowered.com/forums/archive/index.php/t-1103084.html
"I ran the ABR utility and indeed it extracted my windows key that was very different from the one on my sticker. That guide says all I need to do is backup my key with the utility, reinstall vista with the x64 version and choose "activate later", then run the utility that extracted your key again to apply the same -already activated- key."
Ooh, so its doable then. Just need to get my hands on the disc...
So all I need is to use the key in the first link to activate it? I dont need to go through that extraction process?
Second link is for Win 7, dont suppose I could use the Vista key with it?
Not sure on the keys as it can be a ballache with some pcs.
Good point.:bang: I was on auto pilot.
I haven't got time to look at it but have a look at this:
http://www.heidoc.net/joomla/technology-science/microsoft/57-windows-vista-direct-download-links
Dom
Personally I would ditch vista and get a copy of Win7, I changed a few months ago and its miles better IMO.
Are you doing an upgrade from Vista to 7? If so, you can only update like-for-like AFAIK.
You need to do a clean install surely.
