Hello to everyone.
I would like some help from you guys regarding my Fiat Punto Mk2. 8v
I`m having this issue each time I startup the engine. It has been a year or more now always starting like this. However it does not seem to be aggravating.
It starts to shake wobble etc, for about 5 seconds, a little throttle and everything comes back working smooth. Engine light went on from the first time the problem began about a year ago. Error code says that it is coil no2 fault. However I`m sure it is not as I replaced coil no1 with coil no2 and still the same fault was registered again. I suspect that the engine is consuming a little bit more fuel that usual as now I`m doing about 40mpg instead of about 50mpg as I used to do before. Don`t know if this has anything to do with this problem or could it be attributed to something else.
Please take a look at this video http://youtu.be/kF-hDQwdA48
Leander Borg
Malta
Leander Borg
Malta
