D4nny8oy
Established member
Yes, there is an interchanger but it doesn't work. That explains it then, thanks!
I'll get in touch with the parts dept. You seem fairly sure it's just a matter of getting the code, rather than replacing a unit? I hope you're right.
If you can get the emergency start-up procedure to work, it'll then prove if the code matches your Body Computer and Engine ECU or not. If it doesn't work, it then suggests one or more of the ECU's may have been swapped and finding their code near impossible- in which case, replacing the lot for a set that does work is the next viable solution.
It may still be worth getting someone to read the error codes to confirm there's nothing else preventing start-up, though.
