Re: I've fitted Punto GT callipers/disc's!
are gt disks vented?
Donkey said:how much was it for the calipers??
What is with the 'lol', I have rear discs as Aaron suggests.Howard said:Has anyone done rear disc conversions on a Cinq? Lol
FiatExpert said:Is it just me or right at the start at the first pictures, the finished job, why do the pads you've fit do not fit in the calipers.They look a tad on the small side.
Also, as the brake is a bigger diameter than the original, it means the mechanical advantage is greater, so you get more braking for the same pressure.J333EVO said:Firstly, in order to improve any braking system you need to make the contact area bigger, hence bigger disc's with bigger callipers can have bigger pads, therefore a great increase in braking efficiency. It also has the benefit of dissipating heat quicker as there is a greater surface area being cooled down by more air.....
Aaron.
