Re: priming fuel from empty
There is a liftpump in the back.
Prime it with the key couple times and the do 10sec start and let the starter cool down for half a minute.
Repeat.
On old TD you would be cracking the injectors/pump open to bleed them, but do not even consider it with JTD as it is commonrail type.
You could bleed water out of the fuelfilter, should have a point somewhere under the housing.
I've poured ether/brake cleaner to old row/splitter type injectionpump engine manifolds to start them, not sure what commonrail would like about it if the pump is still dry.
