Quick update, parts stockpiling going well, started work on the engine today. Not entirely sure what it is... 1.2 or 1.4. There's just no identifying marks on it anywhere!, nothing on the block bar 16v, nothing above the water pump as there should be, no sticker above the flywheel as there should be. All i know is it came out of a car that is allegedly certain to have meant to be a 1.4 stilo, but it has 1.2 sump and 1.2 cap, but these could easily have been fitted as replacements at some stage though so by no means a certainty.
Really alien engine to work on for me, but learning as i go! Found the setup for removing the rocker cover bonkers, because it's not really a rocker cover, it's a cambox. So you undo 10 plugs with allen keys, then have another 10 screws deep down those holes to undo with allen keys, they are so tight too, felt the allen key was very, very close to snapping more that once but thankfully never.
Another weird thing i found was my engine didn't have the correct head bolts, the standard fiat ribe is way too big for them
so progress got stuck here
also ground the engine mount down to clear the alternator belt.
More stuff on the way so more progress soon
