Technical  Problems after clutch change
Fastritmo
Hi.
I have a Fiat panda 1.3 multijet 2009.
Cant get the car i gear if i sett the linkage where IT Was.
I have to take off the whole braket on top of the gearbox. (Insted of the uniball)
I think i have sett IT back on the same place.
If i sett inn fail i Will get all gears but IT will be vert loose and no return to neutral.
Do anybody knows how to resett the gear linkage?
Sorry for my English.
Thanks, Henning
Was the gearbox gear shift cover been removed during the dutch change? If the levers were not aligned correctly you wont be able to select all the gears.
Set the gearbox in neutral the cables should connect and work correctly. If they wont, it's likely the shifter cover has been fitted with the internal levers misaligned.
Hi Henning,
Here is how the selectors should look if you removed the selector housing, everything in centre in neutral:
Or is it just one of these ball stud brackets you removed?
Are the cables properly connected at the gear lever?
