That would not fit and different , tank i need is thisThere's even several brand new ones on ebay (for peugeot 207/Citroën Berlingo/peugeot partner) for £105 delivered, you'd have to peruse to see if you could adapt it
eBay item number:335451184487 as an example
So your pump appears knackered any way.Compatible to pump and ecu still may throw
Additive pump open circuit back
Wired pump with 12v n ground and tapped pump, getting nothing
What if i cut out pump see if fixable then plastic glueing back?
Brilliant thank you, sounds better than £367Looks like ebay number 276775448484
276775448484 for sale | eBay
Find great deals on eBay for 276775448484. Shop with confidence.www.ebay.co.uk
Just wondering what use glue it all back together
I used the Snap On to prime mine on the 2012 Citroen C3 with the 1560cc diesel, it gets all the air bubbles out so it works correctly.Yes was meant to post chopped tank off replaced motor, nothing on dash, make sure its the correct slow fix araldite stuff, dont buy cheap set like plastic ...bingo, question, does pump need priming with snap on diagnostic or just crack on
