Technical Problem with additive pump
Compatible to pump and ecu still may throw
Additive pump open circuit back
Wired pump with 12v n ground and tapped pump, getting nothing
There's even several brand new ones on ebay (for peugeot 207/Citroën Berlingo/peugeot partner) for £105 delivered, you'd have to peruse to see if you could adapt it
eBay item number:335451184487 as an example
That would not fit and different , tank i need is this
Ebay item number 267242373963
A bit cheaper
So your pump appears knackered any way.
Ask at scrapyard, they often know what will work or not. You can always test it before fitting.
Either way it will probably need any error codes clearing if it has been unable to do a Regen due to pump failure.
I just looked on eBay and the Peugeot one is different, so no help I am afraid.:(
What if i cut out pump see if fixable then plastic glueing back?
Ok im inside the tank, i need find this pump, doesn’t do anything
Brilliant thank you, sounds better than £367
Just wondering what use glue it all back together
If you'd have bought the kit I linked to previously, it comes with some 2 part epoxy (araldite etc) and a bottle of new fluid ;)
Preperation and cleanliness is key , also use the slower curing (24hours) epoxy as it's stronger than the rapid
