Technical Problem 1.1 code 0220 - Throttle Position Sensor
QinteQ
Bump from an old thread !
I cleared the ECU of 3 errors !
A mate loaned me a snap-on ETHOS, took the ETHOS out with me every day until the ' injector icon ' error appeared again, pulled over re-read it showed Throttle Position Sensor [code 0220].
- ere : http://www.shop4parts.co.uk/?name=st...osition+sensor
- I've looked at the diag in autodata and the potentiometer itself is just above the accelerator pedal.
- when the TPS reads a value how does it send it to the engine? - wiring ? - or is it sent to the ECU and then to the engine ?
- anyone any ideas other than changing the unit out which costs £100 ?
- anything else I should look for ? wiring / terminals etc.
- anyone changed one of these ?
