Technical Power steering light, no change in mileage and stalling when stationary
ME03cam
Liverpool
Hi and thank you for having me on this forum. I have a 1.2 petrol 2006 grande punto. This is my first car and it has served me quite well, I’ve just had a new clutch and reconditioned gearbox fitted at a garage, I am only 19 so not really an expert when it comes to cars but have been trying my best to learn as much as possible.
I’ve not long had it back from the garage, the car has had the stalling issue for a while but I can’t ever seem to get to the root of the problem. I have been driving along, become stationary at a traffic light and the engine has cut out: I’ve restarted the car (having had to rev slightly to get it going). Upon driving away have not iced that the speedometer is not working, mpg not showing and the power steering light is illuminated.
If anyone has got any knowledge on this issue it would be greatly appreciated
Thank you so much in advance
Cam :)
Without me sounding too stupid, how do I go about that :ROFLMAO:
Hi
Its NOT complicated
You need an OBD reader..
It reads from the Cars
OnBoardDiagnosic socket
Sat in a punto..it by the drivers right knee
I will try and add a link
In the meantime.. is it convenient to show it to whoever fitted the garbox..some of this may well be related ;)
Its the same from 2006/ 16 ;)
Your car has had a new clutch fitted is the best clue now, so it ran beautifully before but after the clutch job it started, didn't it? Then i'd have to say that it's the main earth cable to the gearbox between the chassis and negative battery terminal. Fit a new cable. Also check the battery terminals that they're clean and not loose.
And I guess when you get a generic code reader, you can only see generic fault codes. If it indeed was the earth cable, you'd get a whole list fault codes which are all wrong. :eek: Also the engine bay fusebox is one source of odd electric issues.
