Technical radio change and mileage indicator flashing
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
dvd90
Spain
Hello!
I installed an Android radio in a 2006 Fiat Grande Punto. After the installation, the odometer started flashing. I then performed a proxy alignment, but when it tries to connect to the radio's CAN bus module, it can't read it. The wiring is correct, and I don't know what to do to get it to read the CAN bus and the steering wheel controls working.
I don't know if the module is correct or if there are any special steps required.
The module is RP5-FT-002.
I've searched the forum and all I see recommended for the 500 are Raisen or Hiwor modules.
Model
1.4 16 v sporting
Year
2006
