Hi thought I'd post an update may help someone down the line...
Took it into FIAT and they diagnosed the fault as the ACCELERATOR POTENTIOMETER
they want £300 squidoolies to replace it...
Funny thing is before I took it to them it would die/stall almost every 1/2mile or so...now it hasn't done it once since being there!!!
Apparently this part is located at the top of the accelerator pedal and the electrical connection is prone to coming lose so I may be lucky for once and not need it replacing...fingers crossed...
Thanks for all the help anyway...
Hi all - first post as I found this (great) site looking for some answers to similar problem.
2001 x reg 105 JTD, is OKish to drive to 3000rpm then hits wall (like the engine has been strangled). The throttle can be pushed/released with little happening, except slight surge when you take your foot off completely. Most driving is in London, so not really a problem, but it is more difficult out of town/motorway (80tops).
This has happened before (2003/4) when I thought the turbo must have blown! When it happened again is difficult to pin-point as our out of town travel is infrequent, but it seems to have got progressively worse (last 4mths). Previously (2004) the throttle wiring was resoldered (no difference) and then New Potentiometer (£300) fitted which fixed it.
My questions are:
Is a new potentiometer likely to last less than 3yrs (like first one)?
> can I buy a pattern part and fit myself for less than £300!
If there are other potential causes what order do I investigate them?
e.g. Throttle Connector Block, MAF Sensor, EGR valve etc.
Many thanks for your thoughts/advice, Miles.
