Technical  Pollen/cabin filter
nfield750
Anyone got experience of changing this. I've looked on youtube, but my 2016 500X cross 1.4 manual seems to have a slightly different installation.
From what I gather you remove the two fir tree plastic clips holding the trim under the glove box
Remove the three torx bolts at the top inside
Then I have two torx bolts at the bottom under the trim
Its still stuck fast and I don't want to damage anything by pulling too hard
This shows you all you need to know (even though its for a LHD - its the same principle -
The clips that hold the Glove Box are very brittle though so you will probably break a couple - has not stopped holding mine back in place though.
One thing when you do this - stick your hand in to fan itself when you have removed the old Filter - its a bit of a squeeze but make sure there are no bits of old leaves and broken 'bits' that have fallen out of the old filter on removal in to the fan itself - you only need a a small leaf left in there to make a really annoying 'hum' on the dash when the fan is on - it needs to be completely clear....
