Fiat 500C 2013 has had problems starting since we got it 3 years ago, but not if used everyday. Mielage flashes all the time. RAC said to get a new battery. Bosch battery fitted, but still the same problem of the battery going flat
Used car everyday and no problem starting.
Last weekend after using car, it then refused to start again to get me home. After a few tries of turning the key, words suddenly stated flashing on the screen:
No Hill Start consult handbook thern
No ABS consult handbook then
No E(and two other letters) consult handbook. Then back to Hill Start again etc
When the breakdown firm came, their battery tester showed the battery was low, but then it rose again even though the engine was off. Was told it needed an new alternator.
Garage fitted new alternator and the car started and test drove, but then wouldn’t start again later because of the battery drain.
Another battery was tried, but still the same problem. Battery charged overnight and it was 14.3 but after a test drive and then the car standing for a while with the engine off, it dropped to 10.6.
Now, sometimes the radio works and sometimes it doesn’t; that hasn’t happened before.
Tried proxy alignment a few times but could't do this.
Blue and Me has been disconnected (under the dash) but there is still a drain on the battery of 3.1v over 24 hours.
Any ideas on what is causing this battery drain?
thanks.
thanks.
