JNAnderson
- Joined
- Dec 8, 2016
- Messages
- 267
- Points
- 43
Only you can answer that.
It's only cosmetic, after all.
True. It can't do any damage to the car driving with a gap though can it?
I'd still want it right. Pop your head under the wing, there should be a tx27 big head bolt screwing into a bracket. Is it there?
They pluttered about unscrewing, shifting and putting back on and moved a screw further down it, but looks the same to me. Will this be right enough? He said the 'lugs' he called them are all clipped in right?
I would suggest that yanking the bumper out of the lugs which is probably how it was removed has bent them so they are holding the bumper fractionally too low.
Looking at your new picture (is yours a satin finish?) The gap looks ok
I don't understand how they could have moved? I'm so stressed with this car now.
If you can afford a decent Japanese car, that is... in my experience the cheaper ones are just as 'disposable' as their European equivalents.Will look tomorrow, my dad summed up Fiats well, they're great whilst under warranty, then after that you need to be good at fixing things oneself or they become quite expensive(parts are cheap its the fitting of them)
If you want a reliable car, get a Japanese PETROL car
Calm, you stress a bit too much, our car is in bits on the drive as I fix numerous "small/large" issues will take some pictures in the morning.
Is it possible for the gaps to come back, without having the bumper taking off again?
Could it go down again and meet the shape it's meant to be?
I get so upset over stupid things but it still don't fall off or anything.
