Hi, I’ve only just notice that you reposted my post. Thank you for your help.
I’ve got no idea re P0504 as this was not mentioned by the electrical place. I was waiting for them to say that they had found the fault and then mention this separate code, but we didn’t get to that point, and the previous garage was unaware of this code. The AA flagged it up, so the P0504 was a bit of a shock to me as it had not been mentioned previously. Re the temp too high, the temp on the dash has been ok, but I will look to see what it is when it next plays up. The AA thought that it was that this indicated that it was an electrical fault.
Why does leaving things make it harder to diagnose later on? Is it because it can lead to more things going wrong down the line I assume? I’m not sure what else I can do where I’ve taken into places and they can’t get to the bottom of it.
I can’t start it or do anything when that symbol is there.
There are no lights on when it doesn’t get the warning symbol. Just feels heavy and the garage said that it was sluggish. I’m not sure about the steering or the city light - re the latter if I press it is there any indication that it is engaged? Only I’ve pressed it before and noticed no difference and it showed no indication that it was on.
There have been a few times when I’ve turned the ignition key and I haven’t liked the sound of the engine.
