Gentlemen, once again I would like to thank you for the help you keep giving me. My Panda does not have air conditioning. The belt tension is set by the adjustable alternator mount. It seems to me that the belt tension is quite strong, but I will still try to tighten it a little more. I will also check the grooves on the pulley. As for the heater core itself, if I wanted to replace it with a new one or flush the old one under high pressure, I suspect it would be best to drain all the coolant again. Or maybe it is enough to partially drain it. Best regards.
