The ignition module in the distributor in the Panda (and Uno ) is prone to causing problems, but it is commonly a complete cut out when hot - and then it will work after cooling down for a while.
....something to consider, if you have no spark but only if its a Magnetti Marelli distributor (sorry you've not said if it's a 4x4 or not)
It would help if you said your exact year/model then we could rule a few things out and stop having to randomly come up with stuff about points/electronic ingition if we knew what you actally had
Jim
Jim
