Hi all.
Anyone able to offer advice on this please?
I've had brake pedal judder on my 15 plate Panda Cross for some time now. Work and other issues prevented me from trying to resolve the problem for some time. I figured the issue was down to a distorted disk so I eventually got around to swapping them over for new along with new pads. Sadly, this hasn't cured the problem at all. The brake pedal still pulses progressively as the car slows. I splashed out on a dial gauge and checked both front disks and saw no noticeable distortion on either wheel. Both were within tolerance. However, it is difficult to turn the disk/hub to check with the driveshafts still attached.
I have seen mention that the ABS sensor ring may be an issue but would that cause the pulsing of the pedal to slow as the car slows?
I have still to change the rears but wouldn't have thought they would have such a noticeable influence on the pedal?
Anyone have any suggestions as to where the problem might be? My next guess would have been a distorted hub but I'm not sure if that's the case or not.
