Now there is the problem, catching it when it doesn't start! It's been fine since doing the fuse box but I'd put money on it doing it again!
Getting fed up with the thing, so far it has completely failed to turn over (my wife was away with the car). Taking out and checking some fuses seemed to fix that but it did it again and a mechanic cleaned the battery terminals (even though it was a new battery) which seemed to fix the not turning over issue.
Had a MAF sensor throw a fault and upon inspection was 'Hella' made in China - it's been replaced with a Bosch one ( no doubt made in China too). Car seemed to run much better, so good in fact that it went into limp mode with 'intake system' fault- turns out wastegate was seized. All fine until I got a MAF sensor fault but that's been reset and not come back.
I can get a graph from diagnostics (I think), what would you like to see?
Voltage, RPM, Fuel Pressure- anything else?
