plonkers
Air conditioning on will knock up to 10% off mpg
That suggests 10% - assuming the engine's generating 40HP at this speed on a light throttle - say 30KW - that would seem to suggest that the aircon consumes about 3KW - I don't know if that's reasonable or not thermodynamically but it sounds like a lot. Does the compressor run all the time on simple aircon (as opposed to climate control, where it cuts in and out frequently)?
On a light throttle at normal cruising speeds, the engine is generating nowhere near 40HP. At a steady 60mph on level ground, it's more like 15-18HP....[/I]
I'm not disputing anyone's opinions/figures (makes a change), I'm just trying to find out some facts, so let's go round again.
Googling "fridge kw" brought up a table showing "room air conditioner" using 1.3KW - which is a bit less but not massively so. The Panda may be a little big car inside but the volume must be a fraction of an average room - about a fifth I should guess at most - room 1000 cubic feet, Panda can't be 200 cubic feet - so, even allowing for relative insulation values, I can't see how the Panda could use more than a quarter of the domestic a/c - say 0.3KW.
So the system in a car is about one tenth as efficient as a domestic aircon - frightening - and surely an area where there should be some significant developments.
Ok all of you. Go to your car, turn it on. Turn of the radio so that the only thing you hear is the engine, let the car ran for 20 sek and listen to the engine, turn on the ac. What do you hear? You hear that the moment you turn on the ac, the engine works harder. It is producing more energy, the fuel consumption is rusing.
And don't forget; don't use it and you lose it.
