I am NOT overfilling oil, never. Always recommended 2,8l = then P1220 appears regularly (per few hundred km), if lowering oil to 2,5l, it appears very rarely, if ever.
Reducing the oil means the engine gets to temperature quicker
Which is why I asked if it failed more often hot or cold, which has been answer of random gave no clues
Power side of Track A of the gas pedal goes off to the coolant circuit, ground side goes off to the compress circuit, exactly how it's all wired up depends on whether the car has Aircon or not, which is why I asked
Its quite likely the power and grounds will be used elsewhere as well
Was a throttle relearn done after the throttle body was changed
Was a throttle relearn done after the gas pedal. Was changed
Earthing checked numerous times.
I am NEITHER an electrician NOR I undestand electricity NOR I have measuring equipment = nogo DIY. But thanks for trying.
