Technical  panda 100HP
fiatbakk
hi all.
i have a problem with getting started .
When I try to start the car it won't start.
it only starts at the 2nd x or even 3rd x
otherwise fine running and starting all day.
many replaced already.fuel pump, spark plugs, map sensor
hi all.
I will leave it to people that own the 100HP to chime in
If it was a 1.1 or 1.2 I would suspect oil / water in the inlet manifold
or dirt stopping the throttle body fully.
Can I ask.
When you start the car do you just turn the key straight round to start or do you pause and allow the fuel system to prime.
Tim
Mine did this when I had a failing coil. it's easy to diagnose with a low cost infra-red thermometer. Start the engine from cold and aim the laser pointer at each of the exhaust stubs close to the cylinder head. The cool/cold stub has a weak coil. You can confirm by swapping the coil with any other and seeing if the cold tube follows the coil.
