Styling  panda 100hp front grille!?!?
dac69er
Established member
suffolk
the grille on my girlfriends 100hp has a hole in it from some tool fitting an auto braking system in the past which is now removed.
it appears getting a replacement for a decent price is nearly impossible as the few breakers that are about are smashed in the front.
my next option is to repair what we have, but would need a section of grille with the same pattern.
does anyone know what other fiats have the same grille pattern so i can try and get hold of one and cut a bit out to use for repair? or if anyone has a broken grille they want to sell on, then i would be interested.
thanks
It had a brake pedal sensor and a brake line pressure sensor fitted so I doubt that. there was also loads of wiring all cut off and a bracket for a control unit that was fitted under the seat.
Anyway, back on topic.
Grille, any other options?
Probably just a brake setup for the car to be towed behind a motor home then (which I suspected in the first place)? Setup would have used the cars brakes to stop it, as it'd have been classed as a braked trailer when attached to the motor home :)
there is no aftermarket wiring to any of the lights and why would there be an aftermarket brake pedal switch fitted if the car was being towed?
i didnt know there was such a thing, sounds a bit excessive tbh. would be cheaper and probably safer to just buy a small trailer!?
