Technical Outside door handle access
diyspanner
2002 1.2 8V Punto
Passenger front is sticking in the open position.
Does the inner panel have to come off to get to the handle hinge and squirt some white grease on?
thanks folks
squirt some oil up the handle on the left and right and then carefully open and shut the handle about 100 times until the handle shuts on its own accord
you might have to repeat the process of oiling during your standing around pulling and pushing
be careful not to break it if really stiff
yes to undo handle inner panel needs to come off and connector to door catch
best to try the external method first
works 99/100
I did the job before getting to your post.
I took the inner panel off thinking the hinge mechanism was inside.
Sadly, as you state above, its on the outside.
Give some WD treatment although its a weird hinge to lubricate.
Work it back and forth as you recommend and its working reasonably well.
Still a bit stiff at the closed position though!
Thanks for posting by the way, appreciate it!
