OT Need Help With RedHat 9
Theres no KDE menu upon boot up unless i press I which does something can't remember.
When i use /etc/inittab i get the following response
bash: /etc/inittab: Permission denied.
Hmmmm.
Joske
Ok found the system settings - then printing,
added my printer, so hopefully will work, will check upon reboot.
Joske
Are you now in KDE? or from a command line?
I have always used KDE (i found it easier :)), try something simple like...
#startkde
Daz
Ok this is the error i get upon boot up with the priniter in the USB port.
Kernel pani: Aiee, killing interrupt handler!
In interrupt handler - not syncing.
I am using the Redhat on the GUI to access the system tools etc.
Joske
Ok i have the KDE already activated when i log on so thats ok.
When i'm on the printing settings i go to add a new print queue, then i add a new one.
Its now asking about the queue type.
/dev/lp0
/dev/usb/lp0 HP Photosmart 7150
The printer isn't plugged in but i tried before hence why it says HP Photosmart 7150.
What to do? ;)
Joske
Sorted it Daz, it needs to be plugged into the USB then you must goto printer settings then add the new queue printer and the USB option will appear and the printer needs to be switched on upon boot up, then let it configure it as it boots up.
All that for a printer, starting to think MS Windows is better.
LOL ;)
Thanks so much for your help mate.
Joske
C
7K
ChrisKnottIns
C
A
5
637
M
1
756
Ozric-Al
O
3
1K
Tommy K
T
