oil pump flow rate
oil pump flow rate
GLASSMAN1953
hi all, im converting my fire engine 1107 spi engine to a dry sump ,( or hoping to ) , its transverse in rear of formula750 single seater ,ive had oil supply problems for ages , even tho its baffled sump ,..does anybody have experience with dry sumping this engine ..thanks dan
Events Team
Join the team
Psst! Are you free August the 1st??
Then come and join us at FIATs and Friends.
Held at the British Motor Museum, there will be loads to see and do so there's no excuse not to be there 😜
Sign up using the link above to register yourself for our stand - everyone is welcome!
Sounds like a great project Dan, and welcome to the FIAT forums!
I can't help you personally, and although this is a bit of a specialist area I don't see why someone else wouldn't have done this at some point
Go for an electric system. You can pre-pressurise the oil system on engine start reducing wear. There is likely to be something made for the 1.4 turbo which may work for your engine.
