Right, that's a lot better. The link you gave www.airbag24.de
only says "Deactivation of co driver and side air bags".
Do you have a link for the actual device you are referring too?
Does it set it permanently for full rapid deployment or staged deployment?
Will the passenger airbag disablement switch still work?
They need to tell you exactly what this modification is going to do and what it is simulating. The airbag ECU is very particular and unless it receives the GO signal from many parameters it won't fire any airbag
Morten
The chld seat has probably deformed the OCS, see if you can straighten it out. The warning will only extinguish after 3 clear starts though.
We can always send stuff out to either of you if it's a lot cheaper here. EU and all that - it ought to be the same price everywhere
Morten
