Technical No Gears available
Gale Force
London
Hi everyone I’m new here and have a problem with my 2008 Fiat 500 Duologic was driving home on M25 when the red gearbox warning light came and a message to check owner manual, I drove for another 35miles with no issues apart from warning light, I stopped switching off ignition to see if would clear fault message and light, I restarted but lights still on and no gears now, just message saying no gears available, got AA to tow me home. Removed heat shield covering fluid resovior and found to be empty!!! Filled to level with Cs Speed and opened drivers door to start pump and fluid disappeared repeated 3 times and fluid disappeared again🙆‍♂️ I’ve been all around the gearbox and no signs of leaks, does it take more than 3 to top up ? Please help I’ve spent hours searching for answers???
Regards Gale Force
Sorry to here of your problems! might i suggest that you post in the 500 specific forum there is aa duologic thread in there, and you might get more views on the subject from owners of the same car!
Regards Gale Force
Hi 👋
It sounds like you have an internal fault 😕
Feel free to post in the 500 sections failure thread,
But there is more practical info elsewhere on here 🤔
As an example
