My Fiat Punto is a 1.2 16V W reg (year 2000).
I have an airbag light on on the dashboard.
So I read several threads on this forum and I bought an ECU diagnostic cable, ebay item 161715574443.
It arrived today.
It consists of a module that plugs into my laptop via USB, and a bag of adapter cables (red, purple, green and yellow).
So, I got the red cable, connected it to the module, plugged it into my laptop and the car, switched the ignition on.
On the module it says Multi Ecu Scan modified ELM.
When I try to connect to the airbag module it says you need KKL/VAG to connect to this module.
Now that I read the Multiecuscan user guide it seems to suggest you need KKL/VAGcom 409 for older airbag modules.
Now I'm guessing mine is an older airbag module, after all its 16 years old this year.
I have a sinking feeling I've bought the wrong ECU diagnostic box of tricks/cable thing. Is this the case?
I have located a KKL/VAG 409 cable on ebay that's only £6.90 with free delivery so its not a total catastrophe.
Will the £6.90 one work with my red, green, purple and yellow adapter cables?
Do I need to fork out this extra £6.90?
Can someone who has done this before please advise?
Mike
It arrived today.
Mike
