Panda (Classic) My Sisley, Panda 4x4 - division north
As mentioned before, I'm starting new thread for my recent purchease.
Bought it from forum user, deposit was place without seeing the car first, went all the way down south with rest of the cash and A-frame in boot.
First summary of the car is ( 1 is very poor, 10 is perfect):
  • Originality - 6,
  • Bodywork - 7,
  • Engine - 6,
  • Gearbox - 5,
  • Interior - 5,
  • Structural rust - 8,
  • Visible rust - 8,
  • Previous owners maintain - 7
Plan for the car is to keep it road worthy and in good mechanical nick, join Panda 4x4 UK club and have some play with other Northern forum members.
As it is now, I'm not willing to make any statement what needs to be done as I had only spend about 2h last week by checking and looking at the car in more details way.
That is my bigger worry for now - bloody milky coolant and a bit of mayo under the oil cap.
How can I confirm my head gasket theory not having coolant presure test kit???
@CLS - your not the only one - aparently it is bloody hard to buy cheepo 4x4 without blown thru head gasket.
The rest of the engine bay seems to be fine,
Did somebody in here mentioned a black silicone gunk as a fast repair?
Interior as you can expect from car been used on a farm
Not the geniune steering wheel and speedo, which does not make much difference to me at all. Roofrack presence evidence
I dont want to know how this happened.
Filler pipe still untouched, what sort of DIY protections do you recon?
And time for the bad boy
Is that gap between the propshaft and diff is normall?
Dear FFCP section members, any comments, suggestions and observation are more than welcome, especcialy regards the 4x4 drive train i.e. leaks etc.
it take me approx. 40 minutes to get the patch done, 30 min extra for welding and smoothing the weld where required. I'll better get to next one...
I don't have a clue why the corner is missing
That's the point where you have to decide is it better to have "one piece" patch or is it faster to weld few flats together. My prefered one are "one-piece" ones.
That bloody corner...I do remember cuttin it off - but why I've done that???
I might by mad, but i've just booked the Hull -Rott ferry for Italia Trip for this car!!!
That's what I call challange, strengely enough two years ago i've been in same situation and tight time schedule with my ex suzuki carry and his preperation to Mangolia Charity Rally.
Did anybody ever drove car onto ferry with number plates of other (panda) car?
Why should that make any difference to them???
Ps. pair of full outer sills just been delivered today, this will save me at least a week.
Floor, inner sill, front wheel arch, front cross membrane are officialy "sound".
Still to do:
front inner sill reinforcement plate, additional 3mm flat plate to go over front cross member, centre cross member- not bother with oe jacking point for now, inner rear wheel arch part 1, trim panel to accomodate new full sill skin, rear inner wheels arch part 2 while outer sill in place, driver side rear sill end patch.
Great progress!
I'm envious of how solid your car is going to be.
Keep it up mate.
That is my problem, I do tend to over-spec things, still needs to decide wich product will be used for future rust protection.
Get new metal welded in is one step, more importants is to protect is right.
Any suggestions guys? I do like the cream OE/Fiat underseal any ideal of the spec?
Don't know mate, it's tight as f**k.
Welding is 70% there from mechanical hubs all round, new rear axle oil seals, hand brake adjusting etc. and get it MOTed and taxed.
It looks like we're in a race, the 750L needs to welding and other bits for MOT - my mate is doing it weekend after next all being well and being MOTed the week before Italy :eek: :eek:
Quick photo update...
boot floor patch
Inner wheel arch
Big Thank You to Vern for pointing out the earth clamp as simple upgrade.
For £3+vat it's doing great job
Small blank grommet was added on for better acceds in future - cleaning or undersealing
Additional reinforsment and seem protection - rear lower inner arch base plate
Had some fun with metal sheet shrinker/stretcher to form inner wing lip
Time to do some work on the front.
Front jacking point/cross membrane repair section - still in flat.
Initially sheaped to fit
Floor, as some sort of datum was required to have the front cross membrane aligne.
More floor - front corner
Complete floor and inner sill
Inner sill front strengthening plate
Finished inside
First coat of Zinc primer
Still lots to do...
