Justin wilson
- Joined
- Nov 22, 2009
- Messages
- 1
- Points
- 1
Hi On a 2000 Multipla we have a knocking from the rear suspension, I replaced the nearside swing arm and still have the knocking. There is play in the bushes at the front of the rear subframe where the subframe mounts to the floor. The bush is not available from Fiat as a seperate item and you have to buy the whole rear subframe for £570+vat + fitting. Has anyone had a similar problem and found a solution. There used to be a similar problem with Mk1 Puntos and Fiat made a cone that fitted over the old bush. There does not appear to be a similar fix from Fiat for the Multipla. Any ideas would be gratefuly received. thanks
