Technical  Multipla Non Starter :(
Just refitted new fuel filter, housing and the new connector and a piece of fuel hose to replace the hose upto where it becomes metal . Tried starting and it was starting, then cutting out. the EML came on and illuminates with the ENGINE CONTROL CONTACT GARAGE message.. Tried starting on and off for 30 mins or so... now its starting everytime ... I cant get it to stall or cut out. Not sure i trust the issue is resolved but its been running now and ive moved it around my drive and it seems to be behaving except for the EML on. Have to clear this and retry ??? So some progress but time will tell if this was the issue .
Hi , I think I have inherited your problem .I bought the car in January from a guy called Paul as an MOT failure .He under played the engine issue and I am now still trying to resolve the fault .I have replaced a number of parts including the injectors but still the same cold start issue .Once running it's fine but just won't start on cold .Can you please tell if you replaced any parts .I'm looking at the fuel filter at the moment to see if it has a pre heater in it which is how I came across your post . The car is Multipla MF57 NVH by the way .Thanks
I read about cold start failure in JTD due to broken tensioner on timing belt, it is worth checking out
