Well, what a lovely day to be crawling around under a Multi
Just about ready to drop the box now, all the necessary gubbins have been removed.
Couldn't see the excellent guide I've looked at mentioned in any of the Gearbox/Clutch work threads (although I didn't fully read through every single page), anyway, even if it is posted somewhere, this may help someone . . .
Multipla clutch replacement
Couple of points;
1. The guide says to pull the O/S drive shaft out (of the Gearbox) before removing the Gearbox, but I didn't do that when I did the Clutch on my last Multi, the Gearbox simply pulls off the shaft, I'll know in an hour or so . . .
2. I found it easier to un-clip the Gear-change Cables from the bracket, rather than unbolt it from the Gearbox.
Couple of points;
