Progress Today...
Clutch replacement:
- Exhaust rubber
- NS driveshaft bolts
MOT:
- Windscreen washer jets
- Blocked spare washer tube leak
- Washer bottle/pump leak
- New wipers
- Checked lights etc.
Exhaust rubber: One of the last few tasks on the clutch replacement project - install front exhaust rubber/hanger. Struggled with this, pushing the rubber onto the 2 rods? off the underside of the car and the front exhaust. I was going to give up and let the garage do it, until I had a brainwave - lubricate the rubber with oil/grease. It worked.
NS driveshaft bolts: Removed each bolt one at a time, cleaned up the thread with my B&D and wire brush attachment, applied threadlock, then semi-tightened. Once all 6 bolts had been done, I went round them all again and tightened to the specified torque (40Nm - from the horses mouth: FIAT).
Windscreen washer jets: Removed and cleaned the washer jets by rotating the internal section until the inner cavity was exposed and then shaking them up in a jar with washing up liquid and hot water. A lot of crud came out. Installed and tested them on the car, really good jets now. Probably would've been even better if I'd soaked them overnight. Anyway it's a vast improvement on no squirt at all, and I saved £16 for 2 new jets.
Blocked spare washer tube leak: The other tube from the washer pump, which I think is supposed to go to the rear windcreen, leaks water from the washer reservoir. I removed my ineffective homebrew screw/stopper from the end of the tube, pushed in some Blu Tack, then some RTV to seal the end. Think that's sorted, however...
Washer bottle/pump leak: This is leaking like a sieve out of the grommet between the pump and reservoir. I think that some RTV would sort this out. Wonder if it'll get through the MOT as is?
New wipers: Put some new windscreen wipers on. I'm always a bit "dyslexic" when it comes to putting the blade on the wiper arm, but I got there eventually. (Aside: I was installing wiper blades on my late Polo once, and the steel wiper arm minus the blade sprung back and put a lovely bullseye crack right in the middle of the windscreen. Never done that before, what genius designed those wipers ?!!!)
Checked lights etc.: Tested operation of various lights for MOT purposes. All appeared OK.
Quick wipe around the dash with a cloth. I'll quickly jetwash the car tomorrow before it goes for MOT prep in the morning. Didn't have time to put on the other wishbone (finished at 8pm), but if the car fails on that, if I can legally get the car home at the weekend, I'll do the wishbone then.
Mark
Clutch replacement:
- Exhaust rubber
MOT:
- New wipers
Mark
