Daz. I can confirm that using silicone to seal the little screwhole in the middle under the wipers is the fix for this problem. Since I sealed mine I haven't had any trouble like this at all. Much better than WD40!
im waiting for a dry day so that I can do this fix as the wd40 didn't work at all.Daz. I can confirm that using silicone to seal the little screwhole in the middle under the wipers is the fix for this problem. Since I sealed mine I haven't had any trouble like this at all. Much better than WD40!
thanks for help. i'm sorry to hear yours is not well. I have (hopefully) attached a pic - have I located the correct screw? thanksI'd take a photo only mine's sick at the dealers. :-(
But yes it does have a screw in it. The rain seeps through there.
is your problem related to the above? How old is your Panda?Yes that's the one. A bit of silicone should do the trick.
Looks like it'll be Monday before I know the fate of my Panda. Kinda expecting the worst.
can anyone advise what i say to them?? i dont want them to start replacing things and leaving me with a massive bill when they might not even fix it. do you guys even think they will find and cure the issue??
I would say this really has something to do with the MAF sensors (air mass cylinder) on the car.
Is the problem happening alot around full throttle?
This won't solve water ingress and won't unbend conrods though.
You're so right, it won't. However, the original post is nothing to do with bent con-rods it's to dowith erratic running after a cold start.![]()
But one type of standard automotive diesel over another will make absolutely no difference at all.
Sorry.
