Depends what part is actually is, the threaded rod with two nuts where you normally adjust the cable of the levers that actuate the handbrake?
I think they are Fiat only parts so grab the bit and if your feeling handy again, get some help and do it yourself or if you need it done quick should be an hours labour max.
mechanic opposite mine has just had a look for me and has said if i get the part he can fit it. I just need to know what im buying. Apparently whoever fittted my handbrake cable over tightened it, so every time i put the handbrake on, it bends the part. The part he described was a thread, any chance you could name the part for me? Thanks in advance
The part which comes from the actual handbrake is £50, it should likely more be the cable I would assume since the threaded rod on the lever is pretty substantial.
