julianps
Hi, our T Reg 60 "Team" has started to misfire and with the ECU warning light coming on goes into "limp-home" all too readily.
Sadly the problem is intermittent and for all I know could have been a bad tankful of fuel ...
On the other hand it could be 'plugs, 'leads, coil-packs, 'head gasket or problems with the recirculation system all of which might be causing the Lambda to throw a wobble and cut the fuelling. The question is which and in which order to check them?
The easy way would be to find the error code and start from there. As a Mk1 it has a small flying lead on the loom just shy of the ECU itself. How would I go about finding a reader and instructions on how to interpret the results?
With thanks, Jules
With thanks, Jules
