T tomek75 New member Joined Feb 7, 2021 Messages 4 Points 2 Feb 7, 2021 #1 The metallic noise when starting the car only occurs once, especially in freezing temperatures. 95 HP engine. Replacing the starter does nothing.What could it be ? Attachments 1VID_20210112_070256.zip 16.3 MB · Views: 84
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 35,001 Points 7,840 Location Near the M4 Feb 7, 2021 #2 Press the clutch down.. any different?
C chris3234 Tipo owner Written a guide Joined Oct 22, 2017 Messages 4,819 Points 1,126 Location West Yorkshire Feb 7, 2021 #3 You zip files contains nothing I'd recommend uploaded the souns/video on to you tube then posting the link here
OP OP T tomek75 New member Joined Feb 7, 2021 Messages 4 Points 2 Feb 8, 2021 #4 The metallic noise at start-up (blinking noise) only occurs once at start-up, especially in cold conditions. Temaperature near zero or below. https://drive.google.com/drive/folders/1RcpI8NqMItJOCwRXIB8Ritlmdjr-b8tE?usp=sharinghttps://drive.google.com/drive/folders/1RcpI8NqMItJOCwRXIB8Ritlmdjr-b8tE?usp=sharing Above is a link to the videos. Sound "empty muffler". Or maybe a catalyst ??? Last edited: Feb 8, 2021
N Neverth Established member Joined Jan 18, 2012 Messages 663 Points 200 Feb 10, 2021 #5 Loose exhaust heat shield?
OP OP T tomek75 New member Joined Feb 7, 2021 Messages 4 Points 2 Feb 10, 2021 #6 Checked shoulder for loose fasteners. Attempt to replace the catalyst ... maybe empty catalyst?
