Folks,
Latest one, 126 650 engine, I get a strange metallic rattle when you go above idle that simmers out at high revs and then comes back into it when passing "a point" to return to idle. There is obviously a frequency/vibration level that is met to trigger this.
Have fitted a rebuilt carb recently and I've done the valve clearance a couple of times as it was backfiring and still is (think it's timing) when it's decelerating so it to me isn't valve clatter.
Tomorrow when it's cooled down I'm going to take the belt off and see if it's something in the fan housing/tinware. I've tightened everything tinware related that I can get a socket on.
Not sure if the video will attach or if it does if it's clear audio wise.
Ta muchly!
Ta muchly!
