Hi All
Iam looking for a little advice and help please
,iam sorry if this has been covered before but iam sure this may be a little different??
Well for those of you that don't know me i drive a 1998 R reg Cinquecento 1.1 1108cc Fire Sporting and currently its running on a stock ecu and chip,but a friend of mine has just gave me his old ecu from his 96 Sporting that he no longer has which was fitted with a Mckrich chip,iam sorry i have no codes from my stock ecu that is fitted to my car at present nor do i have any codes with this new ecu fitted with the Mckrich chip to hand but i can get them if needed not a problem or even Photos of inside of this ecu with this Mckrich fitted if needed
Now with regards to my car it still has the cat fitted but this will be getting removed during the winter as iam starting to get it ready for track use next year,it has already a straight through centre exit exhaust with a focus induction kit but other than that there are no other engine related modifications,yet
Question 1).Can this ecu with Mckrich chip fitted work with my car??,
Question 2).Should i have got keys with this ecu as i have none nor does he have any
Question 3).If this is going to work with my car what is the procedure for removing my ecu and replacing it with this one?vice-versa if i need to fit the other stock ecu back on,
I think i have covered all i need to cover other than codes and such like but as i said i can get them if needed,
Thanking you in advance for you help
All the best Donald
Scuderia
All the best Donald
Scuderia
