Well as promised a little update
Iam pleased to say it honestly couldn't of went smoother than it has,popped the clip removed the 4 10mm nuts and removed the stock ecu then placed on the new donner ecu with Mckrich chip fitted secured the 4 nuts connected it back up turned the key waited until it was primed and Bobs your uncle
,now i left it to run until the fan kicked in and after a few minutes of running with the aid of the light press of the gas pedal the the revs dropped to just below 1000 RPM and what i can tell from sound and vibration it seems to be running the very best so i then took it out for the short blast and as i said iam more than pleased with the result:devil: its there all the time when you need it
its far more responsive than before,i could even go as far to say i was nursing one
easy pleased me
,now obviously the key code light is lit up but i can live with that but iam now on the look out for cat 1 immobiliser alarm but i better trot off and speak nice to the oh
Well i would just like to thank everyone for helping not that there was much to it in the end
but the advice goes a long way so thank you all very much,
Scuderia
