Car is a 2000 1.2 16v cable throttle
This started yesterday, I drove down the road and the fuel just cut out in 6th gear, I coasted to a halt. Started up, driving perfect then it cuts off the fuel again. Staggered home and tried a test drive. I found out that if I pressed the accelerator all the way to the floor, the car would go, badly, but it would drive at least.
Since then I have replaced:
In that order.
The crank sensor is brand new, it improved the car alot but it was still cutting the fuel while driving. After changing the temp sensor and tb with motor the car was going well until about 2 miles of driving, then back to cutting the fuel unless I floored it. All other parts are known good working parts. All the connectors for those parts were cleaned and electrical contact spray applied, all to no noticeable effect. I've gone through the fuel system, the pump is new, fuel injector pipe is new, the o2 sensor is a working part and the injectors are new. Connectors cleaned to match.
Its as if when I'm driving and I don't have the accelerator all the way to the floor, it gets no fuel and splutters or it won't accelerate. All the way to the floor and it goes. Taking off is a nightmare for me, the engine and the clutch as it involves learner style revs to go :bang:
I am at my wits end as it is very difficult to get around anywhere in this car. Has anyone experienced this problem in their own car or can anyone shed some light on this situation? I don't want to have to send it to the local Fiat dealer, 50 miles away
Any help or input is much appreciated!
- Crank sensor
- Throttle body and stepper motor
- Coolant temp sensor
- Air mass meter
In that order.
