James
You have posted in the 500 section - you should repost in the Scudo and/or ICE sections.
Good luck and hope you get it sorted out.
I still don't have a Clarion calculator, wherever he posts it.
James
I'm from Hong Kong and i've bought fiat 500 lounge model 2009, I've lost the radio code, can anyone help? The info is below:
BP: 7647389316
Fiat 7354524860
Many thanks in advance!!
Carrie
Hello Davren,You have posted the Blaupunkt and Fiat part numbers for the radio, you need to post the serial number. For your radio, the serial number will be something like BPX389XXXXXXXX It may be stamped into the side of the radio.
Hello Davren,
Thanks for your advice, the serial number is BP738982380306, hope this can help.
Carrie
That's correct.Hi Davren,
Sorry this is the first time I used this forum, please advise if i need to make a donation for getting the code?
Cheers
Carrie
Oh, I've just got the code free of charge from another forum, thx for your replies before~~That's correct.
Hi. I need a code as well.
Fiat stilo.
M000669
OC
Hi, my radio yesterday asked me for a code - and I have no idea what it is!
Are you able to help me with it?
Many thanks
Edit to say: It is a 2008 Fiat 500 Pop that I have
If you post all the numbers from the back and sides of the radio, I'll let you know if I can get the code.
Ok, thanks.... what do you mean the back and sides of the radio, which numbers? Do I have to detach the radio from the dash to get at these?
Thank you
Thank you
Yes.... you need to take the radio out of the dash.
OK - i've managed to get the radio out, and there's a whole heap of numbers and codes!
From the top:
There's a barcode, with Fiat 312 MPs SB05 written next to the numbers:
71440057027
On the side, another barcode.
BLAUPUNKT GMBH
815BP638389524446
Fiat 312 MP3 SB05
7 646 383 316 034505
Another sticker next to a picture of a circuit board:
BP -Nr
7 646 383 316
Fiat Nr.
735 452 484 0
And on the back of the unit, embossed numbers:
8 635 133 056
DC 01 (cant make out the next two, maybe ZF) 25/25
Is that any good?
Also - the radio display has been saying 'Radio Blocked/Wait' since I put the wrong code in by mistake yesterday, how long does this take to clear? Or can I just pull out the power to it, reconnect it and see if it's cleared?
Thanks!
