Technical Left low beam
Cristian777620
Romania
Hello I have a Doblo 2011 2.0 135 hp and left low beam not working, the rest works. Help me please
Model
Doblo
2011
Mileage
110000
Hello,
Classic, basic analysis:
Is there proper voltage on the connector?
Is the bulb OK?
Is the fuse and relay OK?
What is the effect if you swap bulbs from left to right and from right to left?
Are the bulbs exactly the same and standard for the doblo? or some kind of invention?
The bulb h7 is ok! The car previously had a modified headlight with a xenon lens. Now I completely removed the headlight and bought 2 headlights from abakus. The car is my uncle's and before we changed them, he went to an electrician to change the bulbs because they didn't have enough light intensity (xenon). After that I changed the headlights and the low beam on the left does not work. If it had been a relay, I say that it would not have gone to the right either. The bulb h7 is ok. Fuse ok.
Assuming there's one relay, yes, a malfunction would affect both headlights. Apparently there are 2 separate fuses, the left one operates also the headlight height correction system. Does it work?
It can be hard to find the cause because the installation has been modified earlier and nobody knows how deeply :(
I'd suggest finding the wiring diagrams and making the headlights installation from scratch.
I remember as if the adjustment motor is not working. if not, I was thinking of making an improvisation to draw current from the light bulb on the right..
Check the download section of the forum, there are lots of owners' handbooks, choose the most appropriate one regarding the van production date. It should give the correct fuse guide.
Then, there's also a ressource called eLearn. It's a workshop manual, but according to the information in the appropriate thread it's for the 1st generation Doblo, so won't be helpful :(
